Is there a way to fire up webex embedded app when meeting is ended?
Prashanth Babu
Hi All,
1. Is it possible to open the Webex embedded app once after the meeting is ended?
2. Is there any Webex hook to know that the meeting is ended? ( my requirement is I want to show small pop-up once after the meeting is ended.)
dstaudt
Once a meeting has ended, I would assume the context for any embedded apps for the meeting would be deleted, making doing this from the embedded app JS itself moot.  If there were an 'onBeforeMeetingEnded' event available to the embedded app, that might help; however I don't see anything like that in the current documented events.
You might look at the Post Meeting Landing Page feature, however I don't see that configuring this is possible via API
