Pass STORE Variable to iFrame URL
Daryl Clark
Level 3
Level 3
I am looking to pass a variable from the STORE Data Provider as part of an iFrame URL. For example:
"widgets": {
"comp1": {
"attributes": {
"src": "https://test/{$STORE.agent.agentId}"
"comp": "agentx-wc-iframe"
The value is not being passed, rather the literal string that I put in. Any ideas?
momeraj
class IframeComponent extends HTMLElement {
constructor() {
super();
this.attachShadow({ mode: 'open' });
connectedCallback() {
this.render();
get paramater() {
return this.getAttribute('paramater');
set paramater(val) {
if (val) {
this.setAttribute('paramater', val);
} else {
this.removeAttribute('paramater');
render() {
this.shadowRoot.innerHTML = `
<style>
iframe {
width: 100%;
height: 100%;
border: none;
</style>
<iframe src="https://www.javascripttutorial.net/${this.paramater}"></iframe>
if (!customElements.get('iframe-component')) {
customElements.define('iframe-component', IframeComponent);
1. host this widget somewhere in cloud so that it is accessible through internet
2. in side layout json
     "attributes": {
         "parameter": "$STORE.agent.agentId"
6 Replies 6
ramesh-t
Community Member
I tried above shared code but with my url , buts its not working , is there any other method to get user details in iframe page.
momeraj
constructor() {
super();
this.render();
get paramater() {
if (val) {
} else {
render() {
<style>
iframe {
width: 100%;
height: 100%;
border: none;
</style>
     "attributes": {
Thank you for this, it was super helpful to put me on the right track. I wanted to make it work just how you had it before trying to modify it for my use case. I am just getting a grey screen in my WxCC NAV panel.
                    "nav": {
                        "align": "top",
                        "icon": "share-screen",
                        "iconType": "momentum",
                        "label": "Test IFrame",
                        "navigateTo": "test-iframe-2"
                    "page": {
                        "id": "test-iframe-2",
                        "layout": {
                            "areas": [
                                    "comp1"
                            "size": {
                                "cols": [
                                "rows": [
                        "widgets": {
                            "comp1": {
                                "attributes": {
                                "comp": "widget-one",
								"script": "https://<redacted>/iframe.js"
                    "visibility": "SCREEN_POP"
constructor() {
super();
this.render();
get paramater() {
if (val) {
} else {
render() {
<style>
iframe {
width: 100%;
height: 100%;
border: none;
</style>
ntheolog
Its treating it as a string. A better approach would be to pass it in as $STORE.agent.agentId and the handle it in the widget/app as this.src.
Screen shot:
[A screenshot of a computer code Description automatically generated]
Layout.json
"attributes": {
"src": https://test/{$STORE.agent.agentId}<>,
"src": "$STORE.agent.agentId"
inside web component.
constructor() {
this.src = “”
Somewhere in your code….
Let url = “https://www.test.com/${this.src}<>”
Thanks....I wish I knew what that all meant. Remember this is a "agentx-wc-iframe" so I'm just loading a URL in the page. I don't exactly know what you mean by all of this. Could you share a complete json widget example?
