Presenting an ExternalSource in RoomOS11
rdriscoll
Using RoomOS11 API, I cannot get Presentation ExternalSource working.
I think it's broken and no API documentation has been released for RoomOS11 API yet.
xCommand Presentation Start
^ that command works when no External sources have been added, but if I add a source then the command no longer works (it worked in RoomOS10).
xCommand UserInterface Presentation ExternalSource Add ConnectorId: 2 SourceIdentifier: "Laptop 1" Name: "Laptop 1" Type: "PC"
OK
*r ExternalSourceAddResult (status=OK):
** end
xCommand UserInterface Presentation ExternalSource State Set SourceIdentifier: "Laptop 1" State: Ready
OK
*r StateSetResult (status=OK):
** end
^ A new button named "Laptop 1" now appears on the Cisco UI, happy days so far...
xCommand Presentation Start ConnectorId: 2 Instance: 1 SendingMode: LocalRemote
OK
*r PresentationStartResult (status=OK):
*r PresentationStartResult Instance: 1
** end
^ despite receiving a successful response nothing is presented on the main displays. Pressing the "view" button for "Laptop 1" on the Cisco UI works though.
It used to work in RoomOS10, I am guessing there is a new undocumented command I need to send.
Janos Benyovszki
@rdriscoll please open a ticket with the same by sending an email to devsupport@webex.com . We will check with the Room OS engineers to see if this is a bug.
