Using webex-java-sdk for meetings
ArpitChauhan
Visitor
I wanted to create an integration for scheduling and modifying meetings. Is it possible to use the webex-java-sdk for scheduling meetings? If yes, where can I find the relevant documentation/examples ?
Janos Benyovszki
@ArpitChauhan unfortunately the JAVA SDK is not updated to be used for scheduling meetings. You can however use the REST API https://developer.webex.com/docs/api/v1/meetings to implement your own function for the same.
Janos Benyovszki
