Webex API for monitor the statut of the SIP trunk
I would like use Webex API for monitor the statut of the SIP trunk like you can see it in Control Hub.
Could you tell me if is it possible ?
I just found that API for list all trunks :
https://webexapis.com/v1/telephony/config/premisePstn/trunks
dtibbe
https://developer.webex.com/docs/api/v1/call-routing/get-a-trunk will give you the status of the trunk device. Does that help in your case?
dtibbe
