webex API
1360393739
Frequent Visitor
Frequent Visitor
When I use the https://webexapis.com/v1/people interface to get the list of people, the return value only contains the information of one person, not the other person's information, but in the Webex mobile app, my list contains other contacts
Janos Benyovszki
It depends on what you define as "Contacts". I would assume you mean the list of spaces (group and direct), that you can see in the Webex Desktop app. In that case you can use the https://developer.webex.com/docs/api/v1/rooms/list-rooms API or the https://developer.webex.com/docs/api/v1/memberships/list-memberships API. Memberships is more recommended if you have over 3000 spaces, as it has better performance.
Janos Benyovszki
Thank you for your reply, it helped me a lot,
Janos Benyovszki
@1360393739 please note, that the https://developer.webex.com/docs/api/v1/people API is not meant to show you the list of your contacts, it is there to give you a list of people mainly from your org. If you are admin in your org, you will see all your org users returned. If you are not, you will see your own user returned only.
If I want to get all the contacts, what can I do without using the SDK
