Webex Calling APIs for monitoring from third-party app
alferna
Just to confirm that as per current available Webex Calling APIs is not possible to monitor alarms, thresholds, services status, etc from a third-party tool like Nagios by leveraging Webex Calling APIs, right?
sandiban
Hi @alferna,
Thanks for your patience so far!
To answer your question, I don't think Webex would have the compatibility to be used on a third-party App and I'm not even sure if Nagios would have the option to be integrated with the Webex APIs.
Definitely, you can build an independent monitoring system using the Webex Calling APIs to fulfil certain requirements, but building it with the Nagios won't be possible.
Hope that helps!
Please let us know for any further assistance on the same.
Regards!
Sandip
