Webex Calling Call Control API
erevel
Frequent Visitor
Frequent Visitor
is the Webex Calling Call Control API is providing events (via webhook subscription) in real-time or near real-time?
If near real-time, what is the SLA? seconds? milliseconds?
thanks,
Janos Benyovszki
As mentioned in the generic Webhooks doc https://developer.webex.com/docs/webhooks :
The benefit of using webhooks is that they allow your application to receive real-time data from Webex, so you can keep up with the state of your resources (i.e. rooms, messages, memberships, etc.).
The response is near-real time, because this is a cloud service and the actual time can depend on network conditions and loads at the time of the webhook trigger.
Janos Benyovszki
Janos Benyovszki
@erevel yes, the Call Control API does support webhooks, you can find them here https://developer.webex.com/docs/webhooks under telephony_calls resource. Responses should be near-real time.
Thanks Janos,
But how close to real-time? what is the expected response time?
