Webex Training session requires password
ayshanim
Hi Team,
For creation of webex Training session through  Webex XML API, is the sessionPassword field mandatory to provide the password or Webex will add the password automatically if it is not given.
For creation of Webex Meeting, meetingPassword field is not mandatory and webex is adding the meetingPassword automatically. But for Webex Training session, it gives error for mandatory password. Is there any setting needs to be configured for making webex add automatically password for training sessions also.
Looking forward for the help. Thank you.
Alexander Stevenson
Hello @ayshanim,
According to the Webex XML API Reference Guide
"sessionPassword Optional. Maximum of 16 characters. The password for the event session. If a value is specified, then attendees are prompted for a password before they can join the event session. A null password for this element is the same as not using this element.
The event session password will be validated against the password security options (if enabled) in the Site Administration tool.
If the password security rules are violated, an exception occurs."
Hope this helps!
