WxCC Widget error message: Component not registered
vvazquez
I am trying this example:
https://github.com/WebexSamples/webex-contact-center-api-samples/tree/main/widget-samples/addressbook-widget-sample
it is working running on my latpop, andnow I would like to host bundle.js online. When I try to load the widget it doesn't work, and I can see in the browser console:
"status":"errorRegister","errorMessage":"Script 'myURl/bundle.js' loaded but 'sa-address-book' component not registered"
2 Accepted Solutions
Arunabh Bhattacharjee
Hi @vvazquez ,
This is potentially a hosting problem or an issue in the layout configuration.
For example have hosted these samples for free on the cloud for internal demos and it works well, I will ping you the details 1:1 so you can reuse it.
Thanks & Regards,
Arunabh.
As discussed 1:1 the issue is the Desktop needs the widget hosted on a CDN or file storage, and not a indirect link like the github repo link to the file.
So the solution is to host the bundle.js on a cloud storage of some sort, e.g S3, GCP Cloud storage, onRender, or similar
When checking the "script" tag the layout engine has to render the raw, compiled, JS code as a web component.
Thanks & Regards,
Arunabh.
Where did you store your js file? I'm trying to use this widget as well
I am not sure now, but I normally host them on github
Thanks & Regards,
Arunabh.
Hi @vvazquez ,
Thanks & Regards,
Arunabh.
