Adding users
craig 007
Im a little tecno fear, how do I add users to my webex ? Currently we all log in on the same account but this is messy when it comes to messaging. Anyone help ?
Vaijanath Sonvane
Hi @craig 007,
If you have access to Webex Control Hub, then as a administrator you have multiple options to add users in your control hub. Please see below article:
https://help.webex.com/en-US/article/nj34yk2/Ways-to-Add-Users-to-your-Control-Hub-Organization
If it is just beginning and have basic setup, then you can try adding user manually or using CSV files. Please check out below articles:
https://help.webex.com/en-US/article/v71ztb/Add-Users-Manually-in-Control-Hub
https://help.webex.com/en-US/article/nlkiw8e/Add-Multiple-Users-in-Cisco-Webex-Control-Hub-with-the-CSV-Template
But I would recommend to automate this process by using AD Sync or other options mentioned in first URL.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
dtibbe
Each user may create its own account using its own mail address. Basic accounts are for free, but limited in their features, for sure.
Depending on your use case, you may also buy a paid subscription https://www.webex.com/pricing/.
