02-03-2022 05:48 AM
We are partner with Cisco and one of our customers wanted to try demo free trial for A-flex...How can i do that?
Solved! Go to Solution.
02-03-2022 07:17 AM
If you have access to the Partner Hub (https://admin.webex.com/) you may create a trial from within there.
Otherwise, you may also have a look at https://essentials.webex.com/ or https://dcloud.cisco.com/. There you will find some pre-defined demo scenarios.
02-03-2022 07:17 AM
02-03-2022 07:11 AM - edited 02-03-2022 07:12 AM
Talk to your local Cisco AM or SE
