WebEx meetings dark mode
Eli.Hayon
My request is self explanatory. Just like WebEx teams has a dark theme (dark mode) I would love to see this extended to WebEx meetings. It would be much appreciated to avoid being blasted in the eyes with white all of the time before a meeting picks up and someone starts sharing something. The application is just too bright in my opinion, but I am biased because I used dark theme for everything and it really helps relax my eyes. I am a software developer by trade.
It wasn't a big deal before, but now that I am on WebEx meetings all day every day it would be helpful to lessen the amount of white I am staring at.
Jaime Valencia
I'll move your thread to the user community
https://community.cisco.com/t5/webex-user-community/ct-p/webex-user
And you can place your request here:
https://ciscocollabcustomer.ideas.aha.io/
java
if this helps, please rate
Jaime Valencia
java
Thanks - when I logged into the website SSO kicked in and threw me all over the place. I ended up in that forum so I thought it was the user community.
Im confused by this post.  It says solved but what is the resolution?  What this enhancement added and approved by BU?  This is a much needed feature and would like to get an timeline around this feature. Thanks.
@antonio.warner I am also confused now. I was under the impression my request was moved for me, but I can't find it. I only find this same thread we are on now when I search here: https://community.cisco.com/t5/webex-user-community/ct-p/webex-user
I went ahead and moved my suggestion here just now:
https://ciscocollabcustomer.ideas.aha.io/ideas/WXCUST-I-662
I wish I would have realized it sooner.
@Jaime Valencia you said "I'll move your thread to the user community", was my request moved? If yes, could you put the link here?
EDIT 21:42 ET
The post I made in the collab site was a duplicate. I found one that is older than mine so I moved over to that one: https://ciscocollabcustomer.ideas.aha.io/ideas/WXCUST-I-446
