06-14-2024 04:16 PM
We use NinjaRMM to patch and update our client systems. Webex patches continue to fai.
Does Webex support patching via RMM?
Blake
09-05-2024 06:39 AM
Did you find a solution for this?
06-16-2024 05:58 AM
The most common reason any deployment tool fails to push the MSI is that you missed the install parameters - most notably ALLUSERS=1. You may also want to watch the recording from Deploying the Webex App to your Organization - BRKCOL-2198
06-16-2024 01:33 AM
That's something you should ask the RMM developers
Webex itself ships with the known installers and has its own auto-updater included.
If RMM calls the msi/rpm with the correct parameters, it probably should work. Maybe you can find some more hints in the RMM logs why it's failing..
