Webex patching issue
BlakeCerenzia
We use NinjaRMM to patch and update our client systems. Webex patches continue to fai.
Does Webex support patching via RMM?
Blake
Eric-shook
Did you find a solution for this?
Jonathan Schulenberg
The most common reason any deployment tool fails to push the MSI is that you missed the install parameters - most notably ALLUSERS=1. You may also want to watch the recording from Deploying the Webex App to your Organization - BRKCOL-2198
dtibbe
That's something you should ask the RMM developers
Webex itself ships with the known installers and has its own auto-updater included.
If RMM calls the msi/rpm with the correct parameters, it probably should work. Maybe you can find some more hints in the RMM logs why it's failing..
