Exporting Contacts to CSV file from Outlook for use with Webex Training
Can someone tell me how to export a properly formatted csv file from Outlook for use with Webex Training, please?
Mike_Brezicky
Webex is very temperamental with contact formats.
What I usually suggest is create a manual contact in Webex, then export the contacts. This will provide you the file format that Webex will be happy with. You can then take your outlook export and match up the columns.
