06-15-2020 12:53 AM - edited 07-05-2021 12:10 PM
Is it possible Autonomous AP LED turn on off on specific time ?! I mean e.g. scripting it because in the night it's disturbing, but on daytime it's good to see status.
LED dimming is doesn't work for some reason only full bright (maybe a bug ?) IOS 15.2
Cheers
Solved! Go to Solution.
06-15-2020 01:03 AM
As per my knowledge, there is no way to do it for specific time.
Dont forget to rate helpful posts
06-15-2020 01:03 AM
06-15-2020 02:32 PM
06-15-2020 10:09 PM
If you are good with scripting then ofcourse you can do it.
