Can WLC 4402 support AIR-CAP1602E-S-K9?
Ivan Teo
I had 1 end of life WLC 4402 controller. Can it support AIR-CAP1602E-S-K9 access point? If cannot, what is the supported access points for WLC 4402.
Stephen Rodriguez
The 4402 does not support the 1600 series AP.  The 1600 Series is first supported in 7.4 Code, an the 4400 can only run up to 7.0.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_0_240_0.html#wp784295
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Hi Steve
Thanks for the reply. Another question if i use the below access point with smartnet and configure as standalone AP. But in future if I want to configure to lightweight AP, can i request the firmware from CISCO TAC to flash the AP and make it lightweight? Thanks
AIR-SAP1602E-S-K9802.11a/g/n   Standalone AP, Ext Ant, S Reg Domain
Yes, you can download the recovery image and convert it to work with a WLC.
HTH,
Steve
HTH,
Steve
You don't need a valid Service Contract to download the RCV IOS anymore.
Sent from Cisco Technical Support Wii App
