cisco AIR-ANT2506
juankcs85
Hi everybody
I have a question about  installing a wireless solution with the AIR-ANT2506 connected to the acces point 1242AG-A-K9 (LWAPP) and the goal is register the ap to the controller 2504.
This antenna is supported by the controller?
Thanks.
Stephen Rodriguez
In general, the WLC does not care what type of antenna you use with the AP, so long as they can connect.  The
AIR-ANT2506, is a RP-TNC connector which works on the 1242.
Keep in mind, that under the AP Radio config for 2.4, you'll want to specify the dBi values for the antenna, so that RRM can be calculated correctly.
HTH,
Steve
Please remember to rate helpful posts or to mark the question as answered so that it can be found later.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
That's what i think, but in some cisco links i saw there are some antennas that the wlc didn't support and confuse me.
Leo Laohoo
To add to Steve's post, make sure you configure your radios to the correct antenna.
Wireless > 802.11a/n Cisco APs > Configure > Antenna Parameters > Antenna Gain.
Value entered should be "10".
I'm going to try and post
