Cisco Aironet 1242AG Information
jnihart01
     I'm currently trying to set up a wireless repeater for use in the warehouse section of a business site.  However, due to the AP being hidden/unbroadcasted, I need to get various bits of information from the setup page of the AP device.  While I was able to get most of it (SSID, type of security/encryption, etc.), I can't seem to find information about what channel the AP uses anywheres.  I would appreciate any information I could get that would point me in the right direction.  Thanks!
Scott Fella
Try these commands:
show controllers dot11radio 0
show controllers dot11radio 1
-Scott
I'd have to ask, what standard do these commands follow?  Are these commands for a telnet, cmd, etc.?
Hi Jordan,
You can telnet to the AP and issue above commands. Also you could try this from access point console through hyper terminal.
You should be able to see some output like below and you will have to consentrate on the bold letters for the information you want
1242#show controllers dot11radio 0
interface Dot11Radio0
Radio AIR-AP1242GR, Base Address 0023.ab27.3210, BBlock version 0.00, Software version 6.20.2
Serial number: GAM12412478
Number of supported simultaneous BSSID on Dot11Radio0: 16
Carrier Set: EMEA (EU) (-E)
Uniform Spreading Required: No
Current Frequency: 2437 MHz Channel 6
Allowed Frequencies: 2412(1) 2417(2) 2422(3) 2427(4) 2432(5) 2437(6) 2442(7) 2447(8) 2452(9) 2457(10) 2462(11) 2467(12) 2472(13)
Listen Frequencies: 2412(1) 2417(2) 2422(3) 2427(4) 2432(5) 2437(6) 2442(7) 2447(8) 2452(9) 2457(10) 2462(11) 2467(12) 2472(13) 2484(14)
Beacon Flags: 0; Beacons are enabled; Probes are enabled
High Density mode disabled
Local Rx sensitivity (Config -127, Max -60, Min -11, Active -60) dBm
CCA Sensitivity -64 dBm
Cell Rx sensitivity -80 dBm, CCA Sensitivity -60 dBm,
Current CCK Power: 17 dBm
Current OFDM Power: 17 dBm
Active CCK Power: 17 dBm
Active OFDM Power: 17 dBm
Active OFDM-24 Power: 17 dBm
Active OFDM-36 Power: 17 dBm
Active OFDM-48 Power: 17 dBm
Active OFDM-54 Power: 17 dBm
Active OffChnl Power: 17, Rate 1.0
Allowed CCK Power Levels: -1 2 5 8 11 14 17
Allowed OFDM Power Levels: -1 2 5 8 11 14 17
Allowed Client Power Levels: 2 5 8 11 14 17
Receive Antennas : right left
Transmit Antennas : right left
Antenna: external, Gain: Allowed 4, Reported 4, In Use 4
Active Rates: basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
Current Rates: basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
Allowed Rates: 1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
All Rates: 1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Default Rates: basic-1.0 basic-2.0 basic-5.5 basic-11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Best Range Rates: basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Best Throughput Rates: basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
Current Voice Rates: basic-5.5 basic-11.0 6.0 12.0 24.0 [disabled until voice packet-discard enabled]
Default Voice Rates: basic-5.5 basic-11.0 6.0 12.0 24.0
Channel Range Max Power CCK 18 24 36 48 54 Allowed Levels
1 to 13 by 1 17 17 17 17 17 17 -1 2 5 8 11 14 17
Data Rate Sensitivity (rate, SNR dB, Contention dBm)
( 1.0, 10, -93) ( 2.0, 10, -92) ( 5.5, 11, -90) (11.0, 14, -90)
( 6.0, 15, -89) ( 9.0, 16, -88) (12.0, 18, -88) (18.0, 19, -86)
(24.0, 20, -85) (36.0, 24, -81) (48.0, 27, -78) (54.0, 31, -77)
ERP settings: short slot time.
Hope that helps.
Najaf
Please rate when applicable or helpful !!!
