Cisco WLCCA message question
ALIAOF_
Level 6
Level 6
I'm trying to figure out what exactly is this telling me?
20028,AP: The assigned channel is not in the DCA list. AP slot: 802.11b
I checked the RF Profiles and all areas and for 2.4 GHz only channels 1, 6, 11 are checked.  So why this message?
 The message is pretty clear. If you are sure that all channel are selected properly, that´s pretty weird.  What about the Country Code and AP model ?
-If I helped you somehow, please, rate it as useful.-
I'm pretty sure there is no RF Profile or any custom settings just a global setting and its 1, 6, 11. Country is US
802.11bg:-A    802.11a:-A
Now one thing I'm noticing that AP's with a part number -B in them does not have this error message.
I can understand that for 5 GHz but why for 2.4 GHz?
Update: Found other AP's with 802.11bg:-A    802.11a:-A and not throwing that message.
