ā11-14-2012 01:52 AM - edited ā07-03-2021 11:02 PM
When adding a new MAC filter on WLC .
there are some fields i dont fully understand.
1. Profile Name
2. Interface Name
3. IP address
if i understand correctly to add MAC filtering to specific WLAN , i need to enable thatin the WLANs security tab.
so where do Profile and Interface come in?
and is the IP address a must?
ā11-14-2012 04:35 AM
I just typically set the interface and leave the rest blank.
ā11-14-2012 04:50 AM
does "interface" mean that the MAC filter will only allow access if my MAC is listed & im trying to access the specific interface (VLAN)?
ā11-14-2012 05:03 AM
Yes
ā11-15-2012 12:05 AM
i tested a WLAN with MAC filter enabled.
i added my laptops MAC to the MAC filter list
no matter which Profile Name or Interface i choose, i am able to connect.
so i am still not clear on what the "Profile name" or "interface" fields do.
ā11-15-2012 03:39 AM
Interesting because when I have tested it, it only allows me to connect on the interface I set it to.
ā11-15-2012 05:51 PM
what wlc code?
get, debug client output?
ā02-21-2013 04:57 AM
Hello Jacob,
Was it solved? Anyone knows how to solve that?
ā02-21-2013 05:06 AM
What code are you running and how do you have it setup.
ā02-21-2013 05:21 AM
Hi Scott,
It's a 2504 WLC running version 7.0.220.0 with a single (so far) AP 1041 running IOS 12.4(23c)JA3.
I inserted a list of allowed MAC Address on Security > AAA section
On the WLANs, enabled "MAC Filtering" option
As Jacob stated on the first message, even selecting one specific interface or WLAN, clients (with that specific MAC) are able to join any WLAN
I have three WLANs
- Broadcast SSID + WPA2 PSK
- Don't broadcast SSID + WPA2 PSK
- Broadcast SSID + web authentication (guest wlan)
Also, tried to search on the Bug Toolkit but I can't find the WLC 2500 series.
ā02-21-2013 05:26 AM
I can test it out again... I have a 2504 running 7.4
Scott
Help out other by using the rating system and marking answered questions as "Answered"
ā02-21-2013 05:29 AM
Thank you for testing.
The only solution I see is to upgrade the controller.
Do you know how is this proccess? I'm sorry, but I'm used just to change IOS versions, and never the controller.
Victor.
ā02-21-2013 05:33 AM
The release notes for the code you want to upgrade to has a section on upgrading to new release. Its pretty straight forward, but you might have to do a double upgrade, one for the WLC code and the other is the FUS image. This is all noted in the relase notes.
Scott
ā02-21-2013 05:54 AM
Well the mac filter worked for me... I had to enable mac filter on all SSID's and the profile and interface that I applied my mac filter to, only worked for that SSID and interface. So the issue with this is you can allow only certain mac address to a WLAN SSID, but if you don't have mac filter checked on all your SSID's, then that device can access the other SSID's that do not have the mac filter enabled.
Scott
ā02-21-2013 06:23 AM
Not sure if I did set MAC Filtering on all WLANs.
Will try to test this again and let you know!
