MAC Filter Fields On WLC
Jacob Berger
Level 5
Level 5
When adding a new MAC filter on WLC .
there are some fields i dont fully understand.
1. Profile Name
2. Interface Name
3. IP address
if i understand correctly to add MAC filtering to specific WLAN , i need to enable thatin the WLANs security tab.
so where do Profile and Interface come in?
and is the IP address a must?
29 Replies 29
But understand though.... You would have to put all the devices Mac filters in the list or else no devices will connect if you enable Mac filter on all ssids.
-Scott
This is clear I testes and the MAC Filtering is working. (just allowed MACs are able to connect)
The problem was that interface and WLAN filter "were not working", and this is what I'm going to test.
Thanks!
Let me know. It worked for me.
-Scott
Scott,
I was thinking about this and have one question:
You told that MAC Filtering needs to be enabled on all WLANs.
But how can I do with the guest WLAN? I don't wan't MAC Filter on it, because only guests on the company will use it.
It needs to be simple, with just a temporary user/password.
- Broadcast SSID + WPA2 PSK + MAC Filter desired
- Don't broadcast SSID + WPA2 PSK + MAC Filter desired
- Broadcast SSID + web authentication (guest wlan)  - NO MAC Filter
Well if you have v7.3 or newer, you can enable this feature: On MAC Filter failure
This will keep the devices that are not on the mac filter to still get the webauth page.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Hi Scott,
Enabled MAC Filtering on all WLANs, selected On MAC Filter failure on the guest one (worked!) but I'm still able to connect to all WLAN, even selection just one Profile and Interface on the MAC Filter page, as above
My MAC with permission to access just PDG-Visitantes, using interface visitantes (the interface in use with PDG-Visitantes WLAN)
All WLANs with MAC Filtering (PDG-VISITANTES is also with MAC Filter Failure)
My phone connected on PDG-CORP, even just allowing its MAC to connect to PDG-VISITANTES
Is it right? Do you suggest me to look anything else?
Not solved
My WLC is a WiSM  on a 6500 core switch
Scott Fella
Well I'm running 7.4 on my WLC and I was not able to connect to another profile or interface.
-Scott
Ok, thank you anyway!
I guess that the TAC will be the only solution
Scott,
Just theorizing, Correct me if i'm wrong.
case:1
enable mac-filterting on wlan1 that is mapped to int1.
don't enable mac-filtering on wlan2 that is mapped to int1.
don't enable mac-filtering on wlan3 that is mapped to int2.
case:A macfilter -> mac-A, wlan1, int1.
test cases:-
connect mac-A to wlan1, it should join. bcoz it got right wlan1 and int1.
connect mac-A to wlan2, it should join since wlan2 doesn't have mac filter. ****
connect mac-A to wlan3, it should join since no mac-filter enabled on wlan3 though interface is int2.
case:B macfilter -> mac-A, wlan1, int2.
test cases:-
connect mac-A to wlan1, it should join since int2 used by wlan doesn't have mac-filtering enabled ****
connect mac-A to wlan2, it should join since no mac filter enabled on wlan2.
case:2
enable mac-filtering on wlan1 that is mapped to int1.
test cases:-
connect mac-A to wlan2, shouldn't join since mac-A not allowed on this wlan2
connect mac-A to wlan3, shouldn't join since mac-A not allowed on this wlan3
test cases:-
connect mac-A to wlan1, it shouldn't join since int is different and int2 is also having mac-filter enabled. ****
case:1
test cases:-
All three above is correct
test cases:-
Both above is correct
case:2
test cases:-
test cases:-
Both of these are correct
What I did was I created 4 WLAN's mapped to the following vlans
wlan1>201 ----mac filter enabled
wlan2>202 ----mac filter disabled
wlan3>203 ----mac filter enabled
wlan4>201 ----mac filter enabled
If I assigned a device that was allowed on wlan1 and vlan 201, the device was only able to connect to wlan1 and wlan2.
Now if i set the Any WLAN, the device was able to connect to all 4 ssid's even though I still had vlan 201 defined.
Now if I set the mac filter to allow on wlan1 and set the interface to any, I was only able to connect to wlan1 and wlan2.
So it seems like the Profile Name is mandatory and takes precedence of the Interface name.  So making sure you have the Profile Name configured is important.
Scott
-Scott
Thanks Scott, Much appreciated!!!
No problem. It was about time I lab'd it out anyways:)
-Scott
Go WLANs
Select SSID
e.g (SSID u Select is ABC)
Select Tab SECURITY
Layer 2 Security Select NONE
Mark MAC FILTERING
Select Tab
LAYER 3
Select layer 3 Security NONE
For Adding MAC
Go to SECURIT
Select MAC Filtering
On The Top Right Cornder Click NEW
IN MAC Address Enter Mac As aa:bb:cc:dd:ee:ff:gg
IN Profile Name Select SSID ABC
IN Description Enter any Name ABCMAC (Not Necessary)
IN IP Address Enter IP 192.168.1.1 (Not Necessary)
Interfae Name (Manager Interface)
Jawad
