09-10-2019 09:06 AM - edited 07-05-2021 10:58 AM
Hi everyone,
I need to migrate from an existing 3850 Converged Access mobility controllers to a 5520 WLC. What is the process of doing this in the switch config? I would like to keep the basic config if possible in case I need to roll it back.
In reading the converged access deployment guide:
The setup begins with creating a mobility controller(s) and mobility agent(s). To disable the switch as the AP controller, what are the commands needed? I will need to predownload the 5520 software to the APs and also configure the primary controller IP to the new 5520 as well.
Any help is greatly appreciated.
09-10-2019 12:25 PM
I would simply move APs to new vlan where 5520 IP address provided as DHCP option 43. Then shut down wireless management vlan on 3650 switch.
Rasika
*** Pls rate all useful responses ***
09-10-2019 12:33 PM
Hey Rasika,
Nice to hear from you. I don't think I can create a new VLAN for this customer. Do you have any other suggestions? I'm thinking for each mobility controller (switch stack), i would enter the "no wireless mobility controller" command. Do you know if this will disable the switch as a WLC and allow the APs to search for the new 5520 controller?
09-10-2019 01:16 PM
Yes, that command will stop switch is acting as a WLC
You can try below command on your 3650 & see if that helps (prior to disable wlc functionality on the switch)
#ap capwap backup primary <5520_WLC_name> <5520_mgt_ip>
Rasika
09-10-2019 01:46 PM
Thanks Rasika!
09-10-2019 01:28 PM
You can configure on AP pointing to 5520 on the High Availability tab. Then, shutdown converged access with "no wireless mobility controller".
You can also disable "Enable Dynamic AP Management " on the Management interface of the Switch. This way, the switch will no longer accept Access Point.
-If I helped you somehow, please, rate it as useful.-
09-10-2019 01:45 PM
Hi Flavio,
Would the command be "no dynamic ap management"?
Thanks for your help!
09-10-2019 12:30 PM
Predownloading is nice if you have too many APs or if you have AP behind poor links. Otherwise, you can go ahead.
About the migration process, I think you can export the 3850 WLC config and import it on the 5520. This can save you some time and avoid mistakes.
