PSK issue when migrating AP to a new controller
um1
HI,
I am using cisco virtual wireless controller version 8.3.143.0 with access point 2700 series.
We migrated WAPs to a new vWLC with same configurations. However, after joining the new controller when client tries to connect to PSK based SSID its password is not accepted. When i remove the password from the SSID in the Controller security tab of the SSID and save the password again it works. It happens for every WAP when it joins the new controller. has any faced the same issue or know what i am missing here ?
Rasika Nayanajith
How did you migrate configs to new wlc ? via CLI
Better to manually config the password (in case any copy/paste issues, if you done via CLI)
Rasika
Hi Rasika,
it doesn't happens if we reboot the access point on the new controller. It only happens when an access point joins the new controller. That proves password is same but just doesn't work for any client connected via the AP joined the controller from old to new.
That is weird, sounds like something went wrong by installing the new WLC.
If you want to enforce a reload of an AP while joining the new WLC, install a newer release on the new WLC:
https://www.cisco.com/c/en/us/support/wireless/5500-series-wireless-controllers/products-release-notes-list.html
