RSSI Threshold
zappo0305
Hi everyone,
on the WLC, if I set the "RSSI Threshold (-60 to -90 dBm)" value to -70 dBM and I have clients trying to connect at -71dBM or lower, would they still be able to connect?
Freerk Terpstra
Level 7
Level 7
I assume that you are talking about the "RSSI Low Check" feature which can be configured under "Global Parameters" of 802.11a/n/ac and 802.11b/g/n.
Yes, "RSSI Low Check" does not let a client associate if the RSSI is under the configured value. If you actively want to disassociates a "weak" client you have to use the "Optimized Roaming" feature. This last one needs to be enabled globally and uses "coverage hole detection" information and configuration with a 6 db hysteresis. Use "Optimized Roaming" with caution and make sure you do some testing before and after making changes.
Please rate useful posts... :-)
Venkatesh Attuluri
Client trying to connect at  above RSSI threshold value specified will not be able to connect
gohussai
Level 4
Level 4
Simply , No.
Low RSSI  will not let the client associate if the RSSI is under the configured value.
