07-02-2019 10:40 PM - edited 07-05-2021 10:39 AM
Can one access point associate with 2 seperate wlc's.
For example, can AP-a be associated with corporate network WLC for access to corporate network and a dedicated guest WLC for only guest access.
Customer wants a seperate wlc deicated for guest access. Is this a possible ? If yes then is it not better to have only wlc that can provide guest and corporate access simultaneously
07-02-2019 10:52 PM
Hi @adeebtaqui ,
Single AP can't associate with Multiple controllers at a time. For your requirement you have use the mobility anchor concept.
Please refer this Cisco Unified Wireless Network Guest Access Services for the same.
07-03-2019 12:04 AM
07-03-2019 12:20 AM
You can have any old 55XX controllers add them as Anchor, deployed many sites like this rather using new hardware. like WLC 85XX or new Cat 98XX
07-03-2019 03:51 AM
Can you please elaborate more about this? Is there any document that I can refer to for understanding?
As per your experience and knowledge, which is better, to have a separate dedicated wlc for guest or to just use one wireless controller for corporate and guest.
Can you please share about how to add to cisco wlc , sms notification for Guest access with login credentials
07-03-2019 05:53 AM
It all depends in Environment, what you have backend, you have ISE for the self registration portal
some people use Local authentication with Prime for pre-defined user created and supplied on demand basis to use with expiry date.
If you looking to send SMS, that means self provisioning
https://www.youtube.com/watch?v=6g_smhZKF14
If you have ISE in place, here is the good place to start
https://community.cisco.com/t5/security-documents/ise-community-resources/ta-p/3621621#Resources
