08-17-2011 09:07 AM - edited 07-03-2021 08:35 PM
The WLC documentation would make it appear (or maybe previously) you should download a sample web auth bundle code from the WCS Templates. I was never able to find a sample .tar file on the WCS 7.0.172.0 templates.
However I found on Cisco.com under Support > Downloads > Products >Wireless> Wireless LAN Controller Standalone Controllers> Cisco 5500 Series Wireless Controllers > Cisco 5508 Wireless Controller > Wireless Lan Controller Web Authentication Bundle-1.0.2 > webauth_bundle-1.0.2.zip
It was updated in June 2011, some pretty good sample html code.
The readme.html in the sample webauth_bundle-1.0.2.zip file has been very helpful , almost as good as the suppport community web page on custom web auth.
08-22-2011 02:50 AM
WCS config guide 7.0.172 is correct
http://www.cisco.com/en/US/docs/wireless/wcs/7.0MR1/configuration/guide/temp.html#wp1129979
The bundle in WCS is downloaded through :
configure->controller
"select a command"-> download customized webauth bundle.
Just tested it and it was there.
The one on cisco.com is better though
08-23-2011 06:50 AM
Nicolas is correct is all counts. That is the process in 7.0.172.0 but the web-auth bundle templates you can get off cisco.com are far better and give more options for the web-auth bundle page options.
