RachithaRavindra
This tool is essentially used to generate basic and best practice configurations for the 9800 Controller. The basic configurations include Day 0 Config, Central and Local Webauth, Dot1x, PSK etc. The tool uses a GUI format to take input variables for the specific use cases such as hostname, interface name, AAA server name, Auth List name, and so on. On taking in these inputs, the tool returns the respective CLI to configure it on the device. The user can copy paste this CLI on the 9800 which should help with automatically configuring it. It is aimed at giving customers the best practices for their configurations.
How to use it (Windows users):
  1. Download the zip file onto your local machine
  2. Unzip it and you should be able to see an executable file - “server.exe”
  3. Run the executable
  4. On your browser, type “localhost:7000” and you should be able to see a GUI open up.
  5. The GUI has different options for configurations, you can select each of the tabs to configure specific features.
How to use it (Mac users):
  2. Unzip it and you should be able to see an executable file - “server”
  3. From your terminal, "cd" into the unzipped directory and add necessary permissions for the "server" file - "chmod 7777 server"
  4. Run the file from the same directory - "./server"
  5. On your browser, type “localhost:7000” and you should be able to see a GUI open up.
  6. The GUI has different options for configurations, you can select each of the tabs to configure specific features.
Video of how it works:
https://cisco.webex.com/recordingservice/sites/cisco/recording/play/f0739a7d80ab4c1b81d7451d63a0193b
Password - 4rSjB8f8
1 Comment
French webcast-routing
