Vinay Sharma
Level 7
Level 7
 Viten Patel is working as Technical Marketing Engineer (Converged Access) at Cisco.  He was working as Wireless Escalation Engineer - Cisco TAC and holds many wireless  certification like CCIE Wireless, CCNP Wireless, CCNA Wireless, CWNA, CWSP,  CWAP, CWNE#146.
 This is a video techtorial walking through the Prime Infrastructure WorkFlow for  Converged Access. There are 3 WorkFlows (Small network, Large network and  Centralized network deployment). This video shows the single switch Small Branch flow.
Below is a reference topology and deployment scenario
The WorkFlow helps deploy the above mentioned features. With just a few clicks you can deploy multiple branch networks with all the wired / wireless best practices for Converged Access.
What is achieved?
Some of the benefits of using the WorkFlow includes --
  • Simple to use
  • Masks the configuration complexity
  • Highly scalable
  • covers most of the deployment scenarios
  • configure ones, use many times model
  • intelligence and best practices inbuilt in the tool
  • deploy the network with simple user data inputs
More Information
Video
https://supportforums.cisco.com/video/12513116/prime-infrastructure-workflows-converged-access-single-switch-branch-network-workflow
1 Comment
Viten Patel
http://wirelessonthego.postach.io/post/cisco-prime-infrastructure-workflows-for-converged-access-single-switch-branch-network-workflow
French webcast-routing
