Sahil Mengi
    Introduction
    The data rate display format employed for 802.11ac is,
    Format: aX.YcZ
    X = mcs (modulation coding scheme) 0-9
    Y = No of spatial streams, 1-3.
    Z = Bandwidth 2, 4, 8 (2 = 20Mhz, 4=40Mhz, 8=80Mhz)
    c = b for Beamform, s for STBC, - none
    s = Guard Interval, indicates Short guard interval applicable over LGI (Long guard interval)
    Some Examples
    Datarate: a1.1-2
    X = mcs 1
    Y = 1 (Single spatial stream)
    - = Nodifferentiation for beamform/stbc
    Z = 2 (20 Mhz wide)
    Datarate: a9.1-4
    X = mcs9
    - = No diffrentiation for bf/stbc
    Z = 4 (40 Mhz wide)
    Interesting section from "Sh controllers dot11radio2"
    AP-8-1-11#sh cont dot11Radio 2
    interface Dot11Radio2
    Radio BCM radio, Base Address 0600.0011.ac00, BBlock version 0.00, Software version 6.00.163
    Serial number: FOC17403NF1
    Number of supported simultaneous BSSID on Dot11Radio2: 8
    Carrier Set: Americas (OFDM) (US) (-A)
    Uniform Spreading Required: Yes
    Configured Frequency: 5180 MHz Channel 36 80MHz
    Antenna: Rx[a b c ]
    Tx[a b c ofdm all]
    Internal
    Gain [Allowed 8, In Use 8] (dBi x 2), In Use 8] (dBi x 2), In Use 8] (dBi x 2), In Use 8] (dBi x 2), Reported 0, Configured 0, In Use 8] (dBi x 2)
    Active Rates: basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2 m16-2 m17-2 m18-2 m19-2 m20-2 m21-2 m22-2 m23-2 a0.1-2 a1.1-2 a2.1-2 a3.1-2 a4.1-2 a5.1-2
    Current Rates: basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2 m16-2 m17-2 m18-2 m19-2 m20-2 m21-2 m22-2 m23-2 a0.1-2 a1.1-2 a2.1-2 a3.1-2 a4.1-2 a5.1-2
    Allowed Rates: 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
    All Rates: 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2 m16-2 m17-2 m18-2 m19-2 m20-2 m21-2 m22-2 m23-2 a0.1-2 a1.1-2 a2.1-2 a3.1-2 a4.1-2 a5.1-2 a6.1-2 a7.1-2 a8.1-2 a9.1-4 a0.2-2 a1.2-2 a2.2-2 a3.2-2 a4.2-2 a5.2-2 a6.2-2 a7.2-2 a8.2-2 a9.2-4 a0.3-2 a1.3-2 a2.3-2 a3.3-2 a4.3-2 a5.3-2 a6.3-2 a7.3-2 a8.3-2 a9.3-2
    Default Rates: basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2 m16-2 m17-2 m18-2 m19-2 m20-2 m21-2 m22-2 m23-2 a0.1-2 a1.1-2 a2.1-2 a3.1-2 a4.1-2 a5.1-2 a6.1-2 a7.1-2 a8.1-2 a9.1-4 a0.2-2 a1.2-2 a2.2-2 a3.2-2 a4.2-2 a5.2-2 a6.2-2 a7.2-2 a8.2-2 a9.2-4 a0.3-2 a1.3-2 a2.3-2 a3.3-2 a4.3-2 a5.3-2 a6.3-2 a7.3-2 a8.3-2 a9.3-2
    Best Range Rates: basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2 m16-2 m17-2 m18-2 m19-2 m20-2 m21-2 m22-2 m23-2 a0.1-2 a1.1-2 a2.1-2 a3.1-2 a4.1-2 a5.1-2 a6.1-2 a7.1-2 a8.1-2 a9.1-4 a0.2-2 a1.2-2 a2.2-2 a3.2-2 a4.2-2 a5.2-2 a6.2-2 a7.2-2 a8.2-2 a9.2-4 a0.3-2 a1.3-2 a2.3-2 a3.3-2 a4.3-2 a5.3-2 a6.3-2 a7.3-2 a8.3-2 a9.3-2
    Best Throughput Rates: basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2 m16-2 m17-2 m18-2 m19-2 m20-2 m21-2 m22-2 m23-2 a0.1-2 a1.1-2 a2.1-2 a3.1-2 a4.1-2 a5.1-2 a6.1-2 a7.1-2 a8.1-2 a9.1-4 a0.2-2 a1.2-2 a2.2-2 a3.2-2 a4.2-2 a5.2-2 a6.2-2 a7.2-2 a8.2-2 a9.2-4 a0.3-2 a1.3-2 a2.3-2 a3.3-2 a4.3-2 a5.3-2 a6.3-2 a7.3-2 a8.3-2 a9.3-2
    Current Voice Rates: basic-6.0 basic-12.0 basic-24.0 [disabled until voice packet-discard enabled]
    Default Voice Rates: basic-6.0 basic-12.0 basic-24.0
    Managment Rates: basic-6.0
    Multicast Rates: basic-6.0 basic-12.0 basic-24.0
    Multicast Active rate: 24.0
    RTS Rates: basic-6.0 basic-12.0 basic-24.0
    RTS Active rate 24.0
    RTS Max rate 24.0
    Rateset and MCS maps:
    Default configured rateset and MCS map:
    [Based on configuration only]
    [ 6(b) 9 12(b) 18 24(b) 36 48 54 ]
    MCS SET : [ 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ]
    VHT SET : 0x1 1x1 2x1 3x1 4x1 5x1 6x1 7x1 8x1 9x1
    : 0x2 1x2 2x2 3x2 4x2 5x2 6x2 7x2 8x2 9x2
    : 0x3 1x3 2x3 3x3 4x3 5x3 6x3 7x3 8x3 9x3
    Current operational rateset and MCS map:
    [Based on nss, band and chan width settings]
    : 0x3 1x3 2x3 3x3 4x3 5x3 7x3 8x3 9x3
    Calculate PHY datarate
    For calculating the physical layer speed following formula is applied.
    Formula = { [Bandwidth (As in no. of data subcarriers) x No. of spatial Strms. x Databits per sub-carrier] / Time per ofdm symbol }
    Table for standard values:
    Header 1Header 2Header 3Header 4Header 5
    PHY
    BW (No. of data Subcarriers
    No. of Spatial Streams
    Databits per subcarrier
    Time per OFDM Symbol
    11N or AC20 Mhz (56)1-4
    Up to 5/6 x log^2(64) = 5
    3.6 µs(SGI)
    11N or AC40 Mhz (108)1-4
    4 µs (LGI)
    11AC only80 Mhz (234)5-8
    Up to 5/6 x log^2 (256) = 6.67
    11Ac only160 Mhz (2 x 234)5-8
    Related Information
    http://tools.cisco.com/squish/4E33c
    Amjad Abdullah
    Thank you. That's makes reading the secret code easier. :)
    Florin Barhala
    Level 6
    Level 6
    Hi guys,
    Cisco wireless controller shows one 802.11ac connected client\:
    Current TxRateSet m8 ss1
    Data RateSet 12.0,18.0,24.0,36.0,48.0,54.0
    What theoretical speed is this?
    Thanks!
    mikey71174
    This post is completely worthless.  I have a client showing a current TxRateSet of m15.  Why is it so hard to find out what that means?
    Scott Fella
    Take a look at your controller where you can define he MCS rates.  You will find what MCS rate is equivalent to Mbps.
    -Scott
    Amjad Abdullah
    That means that you are connected with 802.11n and not with 802.11ac.
    In 802.11ac the MCS rates are re-defined and there are only from MCS0 to MCS9 in 802.11ac. If you have any MCS from MCS10 to MCS31 that means you use 802.11n.
    This is one.
    two:
    MCS15 means you are using 64QAM 5/6 modulation with two spatial streams. Now, that provides minimum datarate of 130 Mbps (the minimum is with long guard interval and with 20 MHz channel).
    Now, if you use short guard interval the max data rate will increase to 144.4.
    If you use 40 MHz channel the max data rate will be 270 Mbps and 300 Mbps for long and short guard interval respectively.
    Here is a guide that will help you finding your datarate based on the MCS rate you are on:
    http://docs.aerohive.com/pdfs/Blog/MCS_Chart_802.11ac_v.06.html
    Note that if you are on 802.11n you  should read the table from left to right (HT rates).
    If you are on 802.11ac you should read the table from right to left (VHT rates).
    Here is another resource as well (but the first one above is interactive).
    http://mcsindex.com/
    Amjad
    mikey71174
    Amjad,
    Thank you kindly good sir.  What you provided is exactly what I was looking for, and after I studied it a bit, it all became very clear.  Thanks again.
    Amjad Abdullah
    Anytime buddy. ;)
    jgarciav
    Is there some way to use only MCS 2, 80 Mhz channel and 2 spatial streams with aironet 2102 in autonomous mode??
    Alex Pfeil
    Level 7
    Level 7
    Is there a table that converts these numbers to actual bandwidth?
    6.0, 9.0, 12.0, 18.0, 24.0, 36.0, 48.0, 54.0, m0-2, m1-2, m2-2, m3-2, m4-2, m5-2, m6-2, m7-2, m8-2, m9-2, m10-2, m11-2, m12-2, m13-2, m14-2, m15-2, m16-2, m17-2, m18-2, m19-2, m20-2, m21-2, m22-2, m23-2, a0.1-2, a1.1-2, a2.1-2, a3.1-2, a4.1-2, a5.1-2, a6.1-2, a7.1-2, a8.1-2, a9.1-4, a0.2-2, a1.2-2, a2.2-2, a3.2-2, a4.2-2, a5.2-2, a6.2-2, a7.2-2, a8.2-2, a0.3-2, a1.3-2, a2.3-2, a3.3-2, a4.3-2, a5.3-2, a6.3-2, a7.3-2, a8.3-2, a9.3-2
    Alex
    Alex Pfeil
    Level 7
    Level 7
    This is a good reference for 802.11ac and the equation above. X = MCS (0-9), Y=Spatial Streams, and Z = Bandwidth (20,40, 80 Mhz).
    lemuel_isaac
    This is what Scott is referring to , WLC GUI has the table here. MCS to Data Rate reference.
