TCC_2
Level 10
Level 10
Core Issue
The problem may be caused by any of the following circumstances.
  • Too much distance between bridges
  • Radio frequency (RF) interference
  • Misaligned antenna
  • Bad cable
  • Obstruction
Resolution
Try the following suggestions in order to resolve the issue.
  • Ensure that cabling is properly connected and sealed so no moisture can get into the cable. Also check signal loss value with cable type with your cable manufacturer.
  • Make sure there are no obstructions. Trees, walls, buildings, and hills may obstruct your signal path and reduce signal strength.
Problem Type
Device cannot associate
Products
Bridge
