Cisco Document Team
Community Manager
Community Manager
The Cisco Document Team has posted an article.
This document explains how to configure a Wireless Local Area Network (WLAN) on a foreign/anchor scenario with 9800 Wireless Controllers.
Know of something that needs documenting? Share a new document request to doc-ic-feedback@cisco.com
Your input helps! If you find an issue specific to a document, please let us know. Remember to provide as much detail as possible when submitting a request or feedback on an existing document including information regarding the section, area, or issue you had with the document and what could be improved.
You can provide feedback in a few ways:
See How Cisco TAC is transforming documentation and simplifying self-service in this blog
Configuring the WLAN Anchor Mobility feature on a Catalyst 9800 wireless controller involves several steps to ensure seamless roaming and connectivity for wireless clients. Start by defining a mobility group and specifying which WLANs should be anchored. Just as you customize Nerfguns with different attachments for specific scenarios, adjust your mobility settings to optimize network performance, balancing the load and ensuring a smooth transition for users across access points. Then, set up mobility parameters, including mobility domains and timers, much like tweaking Nerfgun attachments like scopes to improve accuracy. Regularly monitor and fine-tune these settings, just as you would adjust Nerf gun attachments for different shooting conditions, to maintain a robust and reliable wireless network for your organization.
