Gaurav  Kansal
TLS versions enable and disable commands for 8500 series and 9800 series Wireless LAN Controllers (WLCs)
  A very warm welcome to all, I am writing this article for those who are looking to disable TLSv1.0 and TLSv1.1 on their controllers as over the past several years, internet standards and regulatory bodies have deprecated or disallowed TLS versions 1.0 and 1.1, due to a variety of security issues. I tested this on 8500 series and 9800 series controllers on software version 8.5.151.0 and 17.06.04 respectively. Please see bellow commands to configure your WLCs according to your needs.
TLS versions enable and disable on AirOS 8500 series WLC:
Show command to check running versions of TLS on controller
>show network summary
Output: 1.jpg
If secure web mode cipher-option high shows “Disable”, this means all supported TLSv1.0, TLSv1.1 and TLSv1.2 versions are allowed on this controller. Now you can disable TLSv1.0 and TLSv1.1 by enabling this secure web mode cipher-option high by placing bellow mentioned command:
(config)#config network secureweb cipher-option high enable
This will disable TLSv1.0 and TLSv1.1 and only TLSv1.2 will be left enabled on controller for webauth and webadmin. You can verify it from show command.
TLS versions enable and disable on IOS-XE 9800 series WLC:
> show ip http server secure status
Output 17.6.4:  2.jpg
Output 17.9.4:  RichR_1-1697969945651.png
Note that this is the default configuration in 17.9 so there is no need to make any change unless you want to disable TLSv1.2 or TLSv1.3.
Search for this above information, it will display running TLS versions on your controller. Now you can disable TLSv1.1 by placing bellow mentioned command:
(config)# ip http tls-version TLSv1.2
  Conclusion: It is highly recommended to disable TLSv1.0 and TLSv1.1 on the network devices. By following above procedure you may secure your controller.  Check the existing settings before making any changes as the defaults change with each new release.
I wrote this article to share my knowledge and if you have any query, suggestions or want any discussion please leave comments.
To keep your WLC secure you should always use the latest TAC recommended code version as per:
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html and
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/214749-tac-recommended-ios-xe-builds-for-wirele.html
Edited by Rich R to include info for latest IOS-XE versions and links to recommended code versions.
