arthurtoo
Community Member
Hi All,
Is it possible to upgrade my 4402 WLC that is currently supporting 25 AP's to 50 AP's?
can it be done via a software update or is the license tie to the hardware and I will be unable to upgrade?
Thanks in advance!
Arthur Too
jgilbreath
Community Member
arthurtoo
Community Member
Hi Jason,
I've checked under the Q&A section. Apparently,the license is tied to the hardware. no way to add additional license, unlike the 5500 series where its one hardware, and license based.
anyways, thanks for your feedback.
Thank you for your posting and interest in the Cisco Support Community.  For best practices on posting documents in this community you can refer to
https://supportforums.cisco.com/docs/DOC-6022#Can_I_use_documents_to_post_technical_questions
For technical questions related to a Cisco Product or Technology, we encourage you to post on the Network Professionals Forum (NetPro). For your specific issue, you can go to Wireless - Mobility - General forum
liangliangchen
Community Member
you can't upgrade
AIR-WLC4402-25-K9 to AIR-WLC4402-50-K9 ,because the hardware of the two product are different,not base on the license
nfalli1962
The answer is No. I had the same issue and had tyo purchase a 5508. Do not buy the 5508-25 and the 25 license upgrade. That method is mroe expensive. Buy the 5508-50 and you also can upgrade more license in the future.
