cnj_bucks
I am looking for assistance and cannot find documentation on what we are trying to accomplish.
Our current wireless network has autonoumous access points using WPA, PEAP MS-CHAPV2.  Our access points authenticate back to a Windows Server 2003 IAS server.  This works fine.
What we are looking to do is introduce WDS.  We will be configuring one access point as the WDS AP.  What I am unsure about is the documentation talks about creating a username and password.  This seems simple since all of the documentation references using Cisco ACS, but I do not have that available.
I am using the following documentation as a guide, but this only seems to apply if you are using Cisco ACS.
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801c951f.shtml
Thanks in advance for your help.
Thank you for your posting and interest in the Cisco Support Community. We will forward your documentation request to the appropriate team.
For best practices on posting documents in this community you can refer to
https://supportforums.cisco.com/docs/DOC-6022#Can_I_use_documents_to_post_technical_questions
For technical questions related to a Cisco Product or Technology, we encourage you to post on the Network Professionals Forum (NetPro). For your specific issue, you can go to Wireless - Mobility - General forum.
