hkumarsh
In this video you will See -
1. Integration of ISE and WLC.
2. Basic configuration of WLC and ISE.
Cisco Identity Services Engine (ISE) is a next generation product that provides various types of solutions/services in a single box. Example – ACS, NAC, NAC Profiler, NAC Guest Portfolios.
PART 2:- https://supportforums.cisco.com/videos/2480
Wireless LAN Controller
48 Comments
edondurguti
Level 4
Level 4
UPDATE: sorry for not reading your response to prevoius questions.
I see they are renamed... it kinda sucks but anyway.
Thanks for the video.
One question:
on: Policy - Policy Elements - Results - Authorization - Authorization profile..
When i add something and want to apply a task under COMMON TASKS - I don't see POSTURE DISCOVERY :s
I am running a demo on a VM?
any suggesstion?
bilal-javed1
I am new to ISE and ordering one with Cisco
Can you please give me idea what devices i should have already and what i need ?
Do i need to order WLC also with ISE or standalone Wifi AiroAP 2600 will be sufficient whose request are coming through LAN switch 3550?
Also if we dont need WLC, then should we apply three ACLs which Cisco recommends for Posture assessment on ethernet switch?
Please let me know. Thanks
hkumarsh
Hi Bilal,
sorry i am not much aware of Standalone AP. You probably go through config guide of standalone AP. mean while i will also try findout if it's supported.
French webcast-routing
