DevNet Data Center
Share ideas about how to use data center developer tools to help manage virtual servers, deployments and more.
Activity in DevNet Data Center
Catalyst Center (DNAC) PnP API: Cannot Set Stack Member Numbering
Hi @All,Catalyst Center version: 3.1.6I am working on a NetBox-based Zero-Touch Provisioning solution for Cisco Catalyst switches using Catalyst Center PnP.The PnP workflow and CLI template deployment work correctly. However, I cannot define the requ...
Bleblas2 by Community Member
  • 118 Views
  • 0 replies
cisco.dcnm.dcnm_vrf error: 'str' object has no attribute 'get'
When using the ansible cisco.dcnm.dcnm_vrf module I get this error:[NDFC_VRF_ActionPlugin] ERROR: AttributeError in Operation: fabric_discovery: 'str' object has no attribute 'get' Task failed: {'failed': True, 'msg': "'str' object has no attribute '...
ckudari by Community Member
  • 292 Views
  • 0 replies
Poap with n9kv and Nexus Dashboard
I'm trying to set up a CML lab for inband eVPN poap deployment from Nexus Dashboard.So far it's going well but I am running into the boot issue and I'm not sure how to fix it (or if it's even possible).I would like the end result to be:- A user wipes...
Cisco Nexus Backup Python Script
Hello Team ,  am using python script to do TFTP configuration  backup , but am not able to backup as it shows no errors after complete script execution. If I try to do from directly from Nexus device it is working fine.      from datetime import date...
uni1389 by Level 3
  • 1026 Views
  • 2 replies
UCS Cisco C240 M5 DIMM
I've tried multiple DIMMs , and multiple configurations, but anytime I get to this K1 slot I get an error.I'm assuming the slot is bad. Any known issues I should be aware of before I scrap this thing for parts?It's been an absolute nightmare. The fir...
ACI APIC Network-As-Code interface configuration
Hi, I have difficulties configuring vpc port to a couple of leaf-switches.I'm using Network As Code trying to do this. (https://netascode.cisco.com/data_model/apic/interface_policies/new_interface_config)But I'm not able to understand how to do it.I ...
