Enable High Web Ciphering via GUI
RBenke
Does anyone know how to enable this setting via the GUI in 8.3.148? I need it for documentation purposes. As far as I can tell, this setting can only be enabled via CLI, which seems at odds with Cisco's GUI configuration.
config network secureweb cipher-option high {Enable | Disable}
superego
GUI
Security Menu
Web Auth > Secure Web > Cipher-Option High
***Please rate for helpful posts***
superego
GUI
Security Menu
Thank you!
