How to setup CCKM
BJCiscoUser
We are rolling out 20+ APs (1042N-E-K9) and one of the VLANs is used for VoIP. We would like to enable CCKM, but are a little unsure of how to go about it after reading through many of all the documentation. We have successfully enabled one AP to serve as a WDS master, and APs shows up as registered. Below are some of our questions
     1. On the AP, what should be the settings for the SSID on which we want to enable CCKM?
          a. What Encryption Modes are allowed - can we use TKIP or AES-CCMP, or are we obliged to use CKIP-CMIC?
          b. For the SSID, can we enable both CCKM and WPA? And is CCKM with WPA2 supported (chipper AES-CCMP)
          c. For AP Authentication, what Method should we chose? TSL, FAST, or is any of them allowed?
     2. On the client machines (we are testing with a Lenovo laptop, ccx c4, and Intel pro-tools):
          a. We understand that we can choose EAP-TSL for the clients and that should be ok, is that correct?
          b. Do we need to use EAP-FAST or LEAP? And if that is the case, then it seems that MS NPS server as RADIUS is not supported…
We would very much appreciate any help with the above questions, as mentioned we read through the various documentation, but we are still unclear on the above mentioned points.
Greetings!
Erik-Benjamin Povlsen
Stephen Rodriguez
Erik, welcome to support forums!
1.) For CCKM and CCXv4 you should use WPA/TKIP/CCKM.  CCXv5 supports WPA2/AES/CCKM.
2.)TLS or PEAP will work fine.  You do not have to do FAST or LEAP.  IMHO LEAP needs to go the way of WEP and the dodo.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
10 Replies 10
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
Hi Stephen,
Thank you for taking time to answer our questions!
So just to be sure of our setup then, using CCXv4, something like this will be ok?..:
dot11 ssid VOIP
vlan 5
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa cckm
dot1x eap profile TLS
mobility network-id 5
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 5 mode ciphers tkip
And then for the client setup just simple EAP-TSL - with certificates...
Thanks again for helping us out!
the above is not needed.  that dot1x profile is for if you were using the radio as a bridge and wanted to do 802.1x.  WDS goes out over the ethernet to find the 'master' and register/join there for key management.
the mobility network-id command is for WLSM.
but other than those two things that should be removed, the rest of the config looks fine.  Just make sure you define the subinterfaces on the radio and fastethernet interfaces.
HTH,
Steve
HTH,
Steve
Thank you very much, this solved our issues.
Very nice support!
Hi again Steve,
Yesterday we tried the new configuration per your suggestions. But the fast roaming (CCKM) is not working.
We are not exactly sure of what we have wrong in our configuration.
I drop in here two configuration examples, one for our WDS master, and one for a client AP - all test configurations. We would appreciate if you would have an idea of what we have wrong here. Thanks in advance!
## AP-WDS MASTER CONFIG ##
version 12.4
no service pad
service password-encryption
hostname AP2
logging rate-limit console 9
enable secret MyEnableSecret
aaa new-model
aaa group server radius rad_eap
server 10.12.12.12 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius infra_devices
server 10.12.1.109 auth-port 1812 acct-port 1813
aaa group server radius client_devices
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login method_infra_devices group infra_devices
aaa authentication login method_client_devices group client_devices
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 syslog
dot11 vlan-name Network1 vlan 7
dot11 vlan-name Network2 vlan 6
dot11 vlan-name Network3 vlan 5
dot11 vlan-name Network4 vlan 4
dot11 vlan-name VoIP vlan 3
dot11 ssid Network1
   vlan 7
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii MyWPAGuestKey
dot11 ssid Network2
   vlan 6
dot11 ssid VOIP
   vlan 3
dot11 ssid Network4
   vlan 4
eap profile TLS
method tls
eap profile FAST
method fast
username Me privilege 15 password 0 MySpecialPassword
policy-map VoIPTraffic
class class-default
  set cos 6
bridge irb
no ip address
no ip route-cache
encryption vlan 7 mode ciphers aes-ccm
encryption vlan 6 mode ciphers tkip
encryption vlan 5 mode ciphers aes-ccm
encryption vlan 3 mode ciphers tkip
encryption vlan 4 mode ciphers aes-ccm
ssid Network5
ssid Network4
ssid VOIP
ssid Network6
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.7
encapsulation dot1Q 7
no ip route-cache
bridge-group 7
bridge-group 7 subscriber-loop-control
bridge-group 7 block-unknown-source
no bridge-group 7 source-learning
no bridge-group 7 unicast-flooding
bridge-group 7 spanning-disabled
interface Dot11Radio0.4
encapsulation dot1Q 4
no ip route-cache
bridge-group 4
bridge-group 4 subscriber-loop-control
bridge-group 4 block-unknown-source
no bridge-group 4 source-learning
no bridge-group 4 unicast-flooding
bridge-group 4 spanning-disabled
interface Dot11Radio0.6
encapsulation dot1Q 6
no ip route-cache
bridge-group 6
bridge-group 6 subscriber-loop-control
bridge-group 6 block-unknown-source
no bridge-group 6 source-learning
no bridge-group 6 unicast-flooding
bridge-group 6 spanning-disabled
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
service-policy input VoIPTraffic
service-policy output VoIPTraffic
no ip route-cache
bridge-group 7
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface GigabitEthernet0.7
no ip route-cache
bridge-group 7
interface GigabitEthernet0.4
no ip route-cache
bridge-group 4
interface GigabitEthernet0.6
no ip route-cache
bridge-group 6
interface GigabitEthernet0.3
no ip route-cache
bridge-group 3
interface GigabitEthernet0.5
encapsulation dot1Q 5
no ip route-cache
bridge-group 5
no bridge-group 5 source-learning
bridge-group 5 spanning-disabled
interface BVI1
ip address 10.12.1.109 255.255.255.0
no ip route-cache
ip default-gateway 10.12.1.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.12.12.12 auth-port 1645 acct-port 1646 key NPSKey109
radius-server vsa send accounting
bridge 1 route ip
radius-server local
no authentication eapfast
no authentication mac
nas 10.12.1.101 key 0 WDSKey101
nas 10.12.1.102 key 0 WDSKey102
nas 10.12.1.103 key 0 WDSKey103
nas 10.12.1.104 key 0 WDSKey104
nas 10.12.1.105 key 0 WDSKey105
nas 10.12.1.106 key 0 WDSKey106
nas 10.12.1.107 key 0 WDSKey107
nas 10.12.1.108 key 0 WDSKey108
nas 10.12.1.109 key 0 WDSKey109
user wdsuser password wdspassword
radius-server host 10.12.1.109 auth-port 1812 acct-port 1813 key 0 WDSKey109
wlccp wds priority 254 interface BVI1
wlccp ap username wdsclientap password wdspassword
wlccp authentication-server infrastructure method_infra_devices
wlccp authentication-server client eap method_client_devices
wlccp authentication-server client leap method_client_devices
line con 0
line vty 0 4
end
## AP CLIENT CONFIG EXAMPLE ##
version 12.4
no service pad
hostname AP1
aaa new-model
dot11 syslog
dot11 ssid Network1
   vlan 7
   authentication open
   guest-mode
dot11 ssid Network2
   vlan 6
dot11 ssid VOIP
   vlan 3
dot11 ssid Network4
   vlan 4
eap profile TLS
method tls
eap profile FAST
method fast
class class-default
  set cos 6
bridge irb
no ip address
no ip route-cache
ssid Network5
ssid Network4
ssid VOIP
ssid Network6
antenna gain 0
station-role root
bridge-group 1
no ip route-cache
bridge-group 7
no ip route-cache
bridge-group 4
no ip route-cache
bridge-group 6
no ip route-cache
bridge-group 3
no ip route-cache
bridge-group 7
no ip address
no ip route-cache
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
no ip route-cache
bridge-group 7
no ip route-cache
bridge-group 4
no ip route-cache
bridge-group 6
no ip route-cache
bridge-group 3
no ip route-cache
bridge-group 5
interface BVI1
ip address 10.12.1.108 255.255.255.0
no ip route-cache
ip http server
radius-server host 10.12.12.12 auth-port 1645 acct-port 1646 key NPSKey108
bridge 1 route ip
radius-server host 10.12.1.109 auth-port 1812 acct-port 1813 key 0 WDSKey108
wlccp ap username wdsuser password wdspassword
line con 0
line vty 0 4
end
On which WLAN is the fast roaming not working?  If it's the Voice, what model of phone and firmware are you running? FYI 7921/25/26 should be 1.4(3).
if you do a show wds ap on the master, do you see all the AP registered?
HTH,
Steve
HTH,
Steve
The fast roaming is not working on the VOIP WLAN. We are not testing with a phone, but with a Lenovo laptop (softphone), running CCXv4 and configured with (Intel PROSet) WPA - Enterprise, TKIP, TSL with User certificate.
If we run the cmd: show wlccp wds ap, all AP shows up as registered.
If we run the cmd: whow wlccp wds mn detail, the client (associated to another AP) shows up with the following details:
BSS: c8f9.f9a6.f270, SSID: VOIP
Vlan Assigned by AAA: 3
Ntwrk-ID:   -
Key Mgmt: CCKM,  Authentication: EAP
Posture Token:
Up-time: 00:33:36, Lifetime: 127
We have this in the WDS master config, is this ok?
radius-server local
  no authentication leap
radius-server local
radius-server local
radius-server local
Thanks for your help.
Hi Steve,
As an update to my own post, I remember having read somewhere that if we implement CCKM, having the AAA server handing out the vlan id is not allowed/supported, so I disabled that option. That seems to have made things better...
Anyway, we are not completely satisfied with our testing. Is there a command we can run to see if CCKM is working? I remember having read about a command showing the CCKM id assigned to the client?? But I do not remember the exact syntax.
Thanks once again for your time.
Check the ~mn command
Command
Description
show wlccp ap
Use this command on access points participating in CCKM to display the WDS device's MAC address, the WDS device's IP address, the access point's state (authenticating, authenticated, or registered), the IP address of the infrastructure authenticator, and the IP address of the client device (MN) authenticator.
show wlccp wds { ap |mn }
[ detail ] [mac-addrmac-address ]
On the WDS device only, use this command to display cached information about access points and client devices.
ap—Use this option to display access points participating in CCKM. The command displays each access point's MAC address, IP address, state (authenticating, authenticated, or registered), and lifetime (seconds remaining before the access point must reauthenticate). Use the mac-addr option to display information about a specific access point.
mn—Use this option to display cached information about client devices, also called mobile nodes. The command displays each client's MAC address, IP address, the access point to which the client is associated (cur-AP), and state (authenticating, authenticated, or registered). Use the detail option to display the client's lifetime (seconds remaining before the client must reauthenticate), SSID, and VLAN ID. Use the mac-addr option to display information about a specific client device.
If you only enter show wlccp wds, the command displays the access point's IP address, MAC address, priority, and interface state (administratively standalone, active, backup, candidate, or WDS-only).
If the state is backup, the command also displays the current WDS device's IP address, MAC address, and priority.
If the state is WDS-only, the command displays the device's MAC address, IP address, interface state, access point count, and mobile node count.
Using Debug Messages
In privileged exec mode, use these debug commands to control the display of debug messages for devices interacting with the WDS device:
Command
Description
debug wlccp ap
{mn | wds-discovery | state}
Use this command to turn on display of debug messages related to client devices (mn), the WDS discovery process, and access point authentication to the WDS device (state).
debug wlccp dump
Use this command to perform a dump of WLCCP packets received and sent in binary format.
debug wlccp packet
Use this command to turn on display of packets to and from the WDS device.
debug wlccp wds [aggregator | authenticator |nm | state | statistics]
Use this command and its options to turn on display of WDS debug messages. Use the statistics option to turn on display of failure statistics.
debug wlccp wds authenticator {all | dispatcher |mac-authen | process | rxdata | state-machine |txdata}
Use this command and its options to turn on display of WDS debug messages related to authentication.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
you should be able to do a show dot11 association < mac address > and see what the keying is.  or the show wlccp wds mn detail shows that the client is CCKM
HTH,
Steve
HTH,
Steve
