Internal Web Auth
nseja
Good day
i have a problem which is rather weird. i configured web auth (internal) using lobby account to create passwords for guests. however when i test only phones pass the auth stage and have access to internet. difference now is i have tested 2 laptops thus far redirection takes 10mins to pop up. after i submit credentials there is no internet connection. changed browsers aswell
am using both layer 2 and 3 security
thanks in advance
What is the Virtual IP configured on the WLC ? Is it mapped to any URL ?
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
virtual IP:192.0.2.1 (am redirected here when i click on guest)
let me list what am experiencing
1. i choose guest ssid
2.enter password(layer 2 policy)
3.am not redirected to virtual IP
4.i enter 192 manually on url then web page appears
5.i enter username/password that i got from lobby mngt and submit.
6.successful but takes 10-15 mins to have access
NB:this happens on first attempt, after that when you logout and try again #4 is no longer achievable. after few attempts #4 will be achievable.
all phones can connect with no problem
regards
