Query on Cisco Prime Infrastructure TLS version disabling
BhaskarDS
Can we disable SSL2.0 TLS1.0 in Cisco Prime infrastructure ? If so, how ?
I found the command to enable it, but not disable it.
Mark Elsen
 - Not supported. You may want to check the latest version of PI and verify whether unsafe TLS/SSL-protocols are still in place.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi Marce,
Thank you for your reply.
Is there any command to check in the Prime itself to check which TLS version it is running ?
Bhaskar
             %  nmap --script ssl-enum-ciphers -p 443 cisco-prime
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Thank you so much Marce.
