restrict WLAN access based upon device type
wg wireless
Level 2
Level 2
hi,
i have a requirement to allow only certain device types (Apple Ipad only) on WLAN. Dont want to use individual MAC filters due to administrative overheads. Any suggestions?
Scott Fella
The only way you can just allow one type of device is the use of a profiler. Cisco ISE has a profiler, but you will need to get the advanced license also. I don't know how you would be able to do it any other way unless you manually configure each iPad to allow that device on your network.
-Scott
Thanks for reply... can we somehow manage to identify Ipads with its pre-installed certificates?
Or can list of OUI help us in this regard?
Becuase ISE is not available here at the moment.
the OUI list won't help.  it's not specific to the device, just the manufacturor.  So if you were to block by OUI, you would stop all Apple devices from being able to get on the network.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
