04-03-2019 06:31 AM - edited 07-05-2021 10:11 AM
Hi, WLC 5508 code version is 8.0.152.2, do we need to upgrade the code? Thank you
Solved! Go to Solution.
04-03-2019 06:38 AM
- It is always recommended to use the latest gold-starred release for your 5508. Sometimes newer ap-models may require later code too. Usually newer version fixes a lot of bugs.
M.
04-03-2019 06:39 AM
Hi there,
The release you are using is one of the suggested releases for the platform. You will need to look at the release notes for the other three suggested releases and weigh up the new software features each one brings against its compatibility with older Access-Point models.
cheers,
Seb.
04-03-2019 03:21 PM
For you reference the TAC recommended software versions is here:
You will need to confirm software compatibility with your WLC and APs:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Recommend to bookmark both of these for future reference when deciding on an upgrade.
Regarding should you upgrade, whilst it is always recommended to upgrade to one of the latest versions you need to also determine:
04-03-2019 06:38 AM
M.
04-03-2019 06:39 AM
Hi there,
cheers,
Seb.
04-03-2019 07:17 AM - edited 04-03-2019 07:18 AM
Thank you so much for your reply. I can see there are four latest version, 8.5- 8.2- 8.3- and 8.0-. My version 8.0- is latest one. What is main difference among them?
04-03-2019 08:04 AM
A quick scan of the release notes shows no new major software features, but some resolved caveats. Probably the biggest headline which may effect your deployment is the dropping of support for older APs:
Cisco Aironet 1560 Series Access Points
Cisco Aironet 1570 Series Access Points
Cisco Industrial Wireless 3700 Series Access Points
cheers,
Seb.
04-03-2019 08:37 AM
Thank you!
04-03-2019 03:21 PM
