WLC can not ping SVI whiel I can access WLC
vishesh.lib
We recently bought a new WLC. The existing WLC is running on 8.5.110. The new one came with 8.5.131. I believe that we need same OS on both WLC for HA. Interestingly , image 8.5.110 has been removed from Cisco website due to some bugs.So I decided to upgarde the existing WLC. WLC 1 has management IP address 192.168.1.1/24. WLC2 has management IP address 192.168.1.2/24. The gateway is 192.168.1.252/24. From new WLC , I can ping anything in same VLAN including WLC1.I can uping and access WLC1 from my network. But I can not ping anything from WLC1 even the gateway. This WLC is not transferring config file to USB .It is also indicating connectivity issues to reach ftp server and tftp server. I am curious what to do.
10 Replies 10
Leo Laohoo
Is the link a Trunk port or not?
If it is, what allowed VLANs are allowed on the trunk link?
Yes.the link is trunk with all VLAN allowed.
Duplicate IP address?
Don't see duplicate address. managed to download the code to the 3504. But after painful wait of 2 hours, it gave the following error:
transfer failure : version mismatch: the image version is not for this model.
I pushed same file to the new 3504 WLC and it accepted. Checked on Cisco website, it seems to be valid upgrade path. Now I am thinking if it is due to old image on AP
Can you post the complete output to the command "sh sysinfo"?
Removed IP address and location.
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.110.0
RTOS Version..................................... 8.5.110.0
Bootloader Version............................... 8.5.103.0
Emergency Image Version.......................... 8.5.103.0
OUI File Last Update Time........................ N/A
Build Type....................................... DATA + WPS
System Name...................................... WLC3504
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.2427
Redundancy Mode.................................. Disabled
IP Address.......................................
IPv6 Address..................................... ::
Last Reset....................................... Soft reset due to RST_SOFT_RST write
System Up Time...................................
System Timezone Location.........................
System Stats Realtime Interval................... 5
--More-- or (q)uit
System Stats Normal Interval..................... 180
Configured Country...............................
Operating Environment............................ Commercial (10 to 35 C)
Internal Temp Alarm Limits....................... -10 to 80 C
Internal Temperature............................. +59 C
Mgig Temp Alarm Limits........................... -10 to 78 C
Mgig Temperature................................. +45 C
External Temp Alarm Limits....................... -10 to 71 C
External Temperature............................. +39 C
Fan Status....................................... OK
Fan Speed Mode...................................
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 11
Number of Active Clients......................... 10
OUI Classification Failure Count................. 0
Burned-in MAC Address
Maximum number of APs supported.................. 150
System Nas-Id....................................
--More-- or (q)uit
WLC MIC Certificate Types........................ SHA1/SHA2
Licensing Type................................... RTU
I'd upgrade to something more recent.  8.5.110.0 has some scary bugs.
The screenshot shows you're upgrading to 8.5.131.0.
Can you try upgrading to 8.5.140.0?
Haydn Andrews
Is the WLC already in SSO?
You need code to be same on both WLCs to form the SSO if its not already in that state.
TAC recommended 8.5 train is 8.5.140.0
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
Around supported APs with each code:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Other option to do the upgrade is via the service port with a laptop directly connected, and look at using the HTTP option for the file upload.
When you are consoled to the new WLC when it boots do you see any error messages?
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Hi Hydan,
I tried 8.5.140 after TAC recommendation. But I see the same error message. I am uploading files via HTTP as I got a machine on LAN.
The new wlc is fine. It accepts the same image. Now the only problem is to upgrade the old wlc before creating HA.
