1702i WAP: interfaces stuck on vlan 1
David Johnson
"show interfaces" reveals that my physical interfaces are stuck on VLAN 1, but I am not using VLAN 1 for anything, and my native VLAN is 11:
cisco1702i#show interfaces
Dot11Radio0 is up, line protocol is up
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
Dot11Radio1 is administratively down, line protocol is down
GigabitEthernet0 is up, line protocol is up
No "vlan <xy>" lines are possible in the physical interface context, only the subinterface context.
Is it possible to change these assignments, or am I stuck with vlan 1 on these interfaces?
samiinayat.si1
Hi David ,
Could you please change the Native Vlan number sequence .It will be works after the change . Please give the sequence number value in symmetrically .
Thanks ,
Samiullah Khan
