03-11-2011 07:47 PM
I'm trying to find the maximum number of mac filters that are supported on the Cisco 4410N access point. The datasheet says that it supports mac filtering but does not indicate the maximum number of filters. Can anyone help? Thanks.
tc
Solved! Go to Solution.
03-11-2011 11:34 PM
03-11-2011 11:34 PM
on wrvs4400n rev 1.0
Twenty wireless clients.
Best regards
03-13-2011 08:20 PM
Thanks for the reply. However if I'm not mistaken, WRVS4400 is the old access point. Im looking at purchasing the 4410N AP. Company policy states that we have to implement mac filters for all known wireless clients. Therefore I need to know the maximum number of mac filters supported on the latest version of the 4410N AP before going ahead with the purchase. I would be grateful for any help on this. Thanks.
03-14-2011 06:53 AM
Max number of Mac Filter is 20 mac address per SSID
Jason Bryant
Cisco Support Engineer
