Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello,I'm having troubles with AP541N in clustered mode.The problem is that clients connects successfully but get disconnected after seconds without any visible reason.The AP541N is configured to authenticate the clients against a Symantec Network A...
Can anyone assist me on setting up the above Router on 2 Mac Computers on our networkThis mac's are a duel system (using Fusion) & the router works fine on the Windows side.I have airport turned on but I am unable to access the network or internet fr...
my company network have a swith core with many vlans. example Vlan 50 for employ and vlan 75 for visitor. And now i want to config wap4410N with 2 SSID mat 2 VLANS (VLAN 50 math with SSID1 and VLAN75 math with SSID2). but i can't do it. I can create ...
I'm attempting to setup a WRVS4400N with multiple SSIDs:SSID: private WPA2, should have access to wired LAN and internet, and I currently have a Win2008 server running DHCP/DNS on the LAN.SSID: public WPA2, should ONLY have access to internet...
I purchased the RV220W and WAP200 Access Point to setup a small wired/wireless network. The wired network is setup without issue, its the wireless network I am having problems with. I was able to setup two wireless networks on the RV220W on two sep...
Default settingsKey Renewal—Enter a key renewal timeout period, which instructs therouter how often it should change the encryption keys. The default is3600 seconds.If the seconds settings was set at "0" wound the encryption key not change?
We have purchased a CISCO WRVS4400N from PARTH TECHNOCOMM, KOLKATA and the service engineer already installated on 01/02/2011 but we have facing the folloing problems :1. We can not access the wireless link in and arround the three storied building.2...
I have a WRT320N connected to my cable router and I would like to use the WAP4410N that I have to increase the range. In our upstairs office the WRT320N will only connect at 30MPS (appx). Not enough to connect to the NAS and work with large files. I ...
hiim having a issue reconfiguring a AP with CCA. i have a CCA that my old installer never got working properly so now im trying to do it.I have the AP521 connected to the correct port on my UC520 and when i attempt to configure it via CCA i never get...
Hi all,A query here with regards to Wireless isolation between SSID and wireless isolation within SSID.If we have 2 SSID, eg. InternalSSID, GuestSSID on AP1Both SSID are set to Enabled for isolation between SSID, and within SSID, that would mean all ...
I have a room cut off from the wired network by concrete walls (there are windows and it's a very short distance). There is a device in that room with a wired network adapter than needs access to the network. We'd like to use a pair of WAP4410N dev...
Hi!I am having some problems with WRVS4400N v2.We use it just for wired network (wireless is not in use, but it is configured). As a WAN we use PPPoE. Most machines do not use DHCP.After a while (few hours to few days after power up) the router freez...
Hi,i have a problem with WAP200.After 2 weeks of work find the WAP200 don't pass the DHCP package for assign a IP to the client.I have change in client the AP, and the problem remain.I have install in my office the AP, and the problem repeats.I have ...
