Adjusting Data Rate and Threshold
mj32
Hi:
I have CBW240AC access points.
Under Advanced RF Parameters in the controller software, I don't understand the difference between adjusting the 5.0 Ghz (for example) Threshold drop down vs. adjusting the 5.0 GHz Data Rates via the slider bar.
I'm not sure if the above tweaking will help me but this is what i'm trying to get out of it.  I want to stay on 5.0 GHz as much as possible, disable the 2.4 GHz band in the trouble free areas (if possible) but I have some areas where I cannot get good overlap so I want the AP to kick off the client from the 5.0 GHz band and push the device to the  2.4 GHz band, and use 2.4 band to either stay in that weaker area or use it until transitioning back to a good 5.0 GHz area.
thank you
mj32
Wow no one?  I thought this was a fairly basic question for all you out there.
