Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I Have a Problem, since I put the wap 125 into my network.I use a T-System Media Receiver for TV. Since I put the wap 125 in the LAN.This Device dosen't work and an Error ist Displayed: There ist a Device on the LAN which uses an older IGMP Version.T...
Hello,We have 3x CBW240AC access points covering about 1000 sqft with about 15-20 devices simultaneously connected (mostly Apple devices). 4 SSIDs are broadcast, including a Guest network and 3 different VLANs for different usages (contractor / staff...
Hello all I have a Cisco WAP4410N servicing a small office for drop-in technicians to connected to our LAN, no heavy traffic or fancy management set up, they just see it as a wireless access point they can connect to for internet and access some Samb...
Hi,We are using a WAP125 in a small office.Everything is fine, except that every morning at 11:00, all the computers and printers connected to this Access Point loose network access (but work OK if connected to the Zyxel access point or the old WAP1...
Gooed morning, i know some basics about networking and vlans, but i know setting up a cisco device can be sometimes challeging.i can buy a sg300-10 l2/l3 switch.my home situation is router, giving ip adresses through a small dhcp pool to all my devic...
Buona sera, con l'access Point cbw240ac-e non riesco ad aumentare la velocità' di navigazione.Facendo uno speed test non vado oltre i 50 mbps e secondo le specifiche dovrei arrivare fino a 867 mbps.Precedentemente con un WAP150 arrivavo circa 500 mbp...
Hi community, just realized tht a new software version 10.3.1.1 is avaiable for CBW140/145/240 AP but I could not find any release notes about this version. Does someone have an idea where this can be found? Thank you in advance. Regards T.
I have setup this AP and successfully directed a new WLAN ssid to my windows RADIUS server and can connect a client OK, However my RADIUS attributes should also give the client a custom VLAN and it doesn't so I suspect there may be Cisco specific att...
Wrestling with these WAPs for almost a year now and the hopeful resolution, I believe, is contained in this thread—meaning wait for a firmware patch that's allegedly under active development.Countless other threads on 581s flapping, 'losing wireless,...
Hello,After 5 years of perfect usage providing extended wifi coverage to my office, my WAP321 has stopped working after a power cut. Ive tried the usual reset & turning it off and on along with downloading the Cisco FindIT application to try and find...
A client contacted me for assistance with their wireless network. They had just purchased three WAP121 wireless access points and upon setting them up discovered the devices provided extremely slow access to the Internet. They have cable Internet ser...
BlueStreams Group will like to renew its Cisco Partnership. What is the process? Where can we start? We have a lead opportunity for quote. Thanks and regards,John Abbeyjohn.abbey@bluestreamsgroup.com(202)469-9895
Hi Folks,we run several non clustered WAP571 (latest firmware v1.1.0.3) in our company network. New company policy says to implement MAC filtering. As I don't want to create a seperate MAC-list in every WAP, I set up a FreeRadiusServer, tested it wit...
